how much to change a synchros?
Old 09-24-2008, 03:35 AM
mikes_tt's Avatar
Default how much to change a synchros?
started reading around the net about the clunking noise i'm hearing when shifting from 2-3rd gear and it looks like its the synchros that might be the problem... how much is repairing the 3rd gear synchros gonna cost me??
Old 09-24-2008, 09:06 AM
jakej's Avatar
Bad syncro's usually cause the gear to grind, not a clunk.
It is huge $$$ to replace them. Most people just replace the entire trans.
Old 09-24-2008, 09:33 AM
bvgoosedd's Avatar
i'm surprized to here that. we would you replace the trans and not rebuild it. at least when you rebuild it you know you kinda have a whole new trans. or do you mean replace with a new trans??
Old 09-24-2008, 09:41 AM
Murderface's Avatar
02J 2nd gear grind fix ... parts off "moclov"'s invoice:
[2] - G-005-100-A1 - oil, .5 litr
[1] - 00076 - brake klee
[1] - 02J-311-239-J - synchr hub
[2] - 02J-311-247-C - synchr ring
[1] - 02J-311-261-K - 2nd gear
[1] - AMV-188-200-03 - seal comp
[3] - G-005-100-A1 - oil, .5 litr
02M 2nd gear grind fix ... parts off "genxguy"'s invoice:
[1] - 02J-311-251-J 1st gear
[1] - 02J-311-261-L 2nd gear
[1] - 02J-311-239-J synchr hub
[2] - 02J-311-247-C synchr rng
[2] - 02J-311-277-A synch ring
[2] - 02J-311-279 Outer ring
[1] - 02A-311-531-K reversgear
[2] - G-005-000 Oil-1 litr
There ya go...
Old 09-24-2008, 01:57 PM
precision tt's Avatar
the reason why people replace the tranny is the cost. a used working tranny is 1500-2000 to repair mine in california cost 1200. and a week. The downside to a used tranny is the syncros could go out in a week. then you double the labor and are out 1500. get it fixed and get it done by someone who has worked on the audi or vw golf transmisions. i am done going to the "universal"shops. they know a little about everything but not enough about anything, and when your car braks due to shoddy labor its your fault. I went to a small shop in San Jose to replace my axles. i drove the car 2 times a day for 3 miles to and from work. after 1 month my front wheel came loose (didnt fall off the car) and destroyed my front brake assembly. Guess what it wasnt their fault the mechanic didnt tighten the wheel down. The wheel should have fallen off the first day. i drove the car 200 miles.
Old 09-24-2008, 10:12 PM
mikes_tt's Avatar
great news.. it was nothing just my shifting i guess...
Old 09-24-2008, 10:48 PM
theTTkid's Avatar
just your shifting? what? how?... just learning?
Old 09-24-2008, 11:23 PM
XCLR8TT's Avatar
Push down the left pedal when shifting gears.....
Old 09-24-2008, 11:35 PM
theTTkid's Avatar
^oh, thanks for the tip
Old 09-25-2008, 09:30 AM
Maybe your clutch needs adjusted?? Just a thought
Quick Reply: how much to change a synchros?
