How do you tell if fuel injectors are bad?
Old 08-29-2007, 11:30 PM
theTTkid's Avatar
Default How do you tell if fuel injectors are bad?
So im still trying to figure out what this weird sound is... It sounds like a clunk... it seems to happen during times associated with fuel and is really bad/loud/noticeable at idle... idk what the sound could be. any thoughts?
Old 08-29-2007, 11:41 PM
andrei's Avatar
Default RE: How do you tell if fuel injectors are bad?
with ac on or off... i have a lot of different noises at idle too..
Old 08-29-2007, 11:49 PM
theTTkid's Avatar
both... it sounds even worse with my a/c on... but even with it off i get a good bit of clunkin around... i get it when i shift into 2nd and up or downshifting into any gear
Old 08-30-2007, 02:45 AM
p1zl3's Avatar
Is it like an engine knock? Because that's pretty bad and you shouldn't drive it....at all. My Porsche had a slight knock and that knock quickly turned into a *BANG* going 60mph around a corner and the engine siezed. Get her checked...
Old 08-30-2007, 09:31 AM
theTTkid's Avatar
will the timing belt start to yell at you before it breaks? or would that just break?
Old 08-30-2007, 09:35 AM
ouTTie914's Avatar
Usually it's the tensioner that goes first, silent but deadly!
How many miles are on your clock?
Old 08-30-2007, 09:37 AM
theTTkid's Avatar
~60
Old 08-30-2007, 09:42 AM
ouTTie914's Avatar
Personally I'd get a bottle of injector cleaner and put it in the tank, while looking for timing belt kits!
dieselgeek or www.ecstuning.com Take your pick, but I believe the diselgeek kit is more complete and cheaper.
Old 08-30-2007, 09:44 AM
theTTkid's Avatar
ugh, i have been dreding this timing belt day... i am going out of town today so maybe i'll throw it into the shop for a few days and see whats up.
Old 08-30-2007, 09:47 AM
ouTTie914's Avatar
Preventive maintenance isn't something to dread. You've read the posts of what happens when timing belts fail.
It's not pretty, and very costly!
Quick Reply: How do you tell if fuel injectors are bad?
