How do I remove the tire
Old 12-29-2007 | 11:23 PM
SRStunts's Avatar
Default How do I remove the tire
I know that sounds dumb... but how do you get the tire off? I'm not sure how to remove the cover over the lugs. I bought the car used and there is no manual.
Old 12-29-2007 | 11:27 PM
theTTkid's Avatar
Default RE: How do I remove the tire
there is a tool in your trunk shaped like a U with 2 teeth on the inside of it... use that to pull off the lug covers... it should be to the right of your spare
Old 12-29-2007 | 11:28 PM
SRStunts's Avatar
Yea... that tool is missing. Any other ideas how to do this without that tool?
Old 12-29-2007 | 11:33 PM
theTTkid's Avatar
try needle nose pliers
Old 12-30-2007 | 02:14 AM
achTTung's Avatar
I've used plyers in the past, I have a good assortment, some shapes work better than others
Old 12-30-2007 | 09:53 AM
SRStunts's Avatar
Is this tool specific to the TT... or do other Audis also need it?
Old 12-30-2007 | 01:41 PM
jakej's Avatar
most cars in general use the tool. You can prob find one at an auto parts store. ask for the lug nut cap removal tool. Otherwise, maybe try a small bent screw driver. They are hard to remove even with the tool tho.
Jack_Tauson_Sr
01-28-2015 11:31 PM
matthayzon89
08-10-2013 01:14 AM
fidelite
06-24-2008 03:06 PM
seaurchin99
05-27-2005 12:39 AM
