Hood MOD Idea?
Old 03-27-2007 | 01:07 AM
moeron7's Avatar
Default Hood MOD Idea?
Has anybody ever thought of either customizing your oem hood or having one made that might have some slits or an opening on the driver side right where the intake would be? I have the modshack VTDA and thought it would be great to have an open slit right there for some cool breezes.Think this is a good/bad idea? The two downsides I see of this is a) water and debris could get in there so you might have to make some kind of shield and b) it may look too ricey. Anybody ever seen this?
Old 03-27-2007 | 01:12 AM
diehlryan's Avatar
Default RE: Hood MOD Idea?
Old 03-27-2007 | 01:21 AM
XCLR8TT's Avatar
Old 03-27-2007 | 01:23 AM
moeron7's Avatar
LOL Man that is a huge pile of steamy rice. I guess no +1 on that idea. How bout a 3" cowl induction? Ok that was a joke
Old 03-27-2007 | 01:25 AM
cincyTT's Avatar
I'm make believe
steve, is that a motorcylce head light modded into a scoop?
Old 03-27-2007 | 01:28 AM
achTTung's Avatar
The area above the hood is somewhat a low pressure area anyway, if anything, air would be drawn up and out of the hood, not sucked in, unless you'er using a motorcycle headlight. ; )
moeron7's Avatar
ORIGINAL: XCLR8TT
HOLY! that is a little more than I was thinking. Looks like that thing will shoot potatoes out of it. I was just thinkin of a couple slits but I guess they had the same thought as I.
Old 03-27-2007 | 01:31 AM
XCLR8TT's Avatar
I believe it is a custom design from Messerschmitt Design, AFAIK it's a custom one off ram air scoop. He even has a TTDA hooked up to it.
Old 03-27-2007 | 01:33 AM
TTsteve's Avatar
I would think that some kind of scoop down and inside the the grill where the air can come in and have the scoop (full length of the bumber if possible) slant upwards so the air then goes up in the engine and helps cool things off. I would think that cooling the whole engine and the air after the turbo would be more benificial than jsut the intake air. On the 180 when I took out the SMIC for the FMIC it looked like there was a plastic piece that was suppose to help angle the air flow to the IC. So something like that.
Old 03-27-2007 | 01:39 AM
moeron7's Avatar
ORIGINAL: TTsteve
Yeah I know what you're talkin about, that might even work as well. I dont think there is enough room thought with the batter right there.
