Help with Wiring -- Splicing
hey does any here have an ecm wiring diagram and also any wiring diagram that will display which color wires i can tap into for:
engine speed, Throttle positioning, injector duty cycle
i think thats it. basically i need to tap into these readings and any wiring diagram/help is really appreciated.
RE: Help with Wiring location
well i managed to locate each wire at the ecu and also color match them etc etc.
so now the new task becomes as follows.
HOW TO TAP ITO THEM?
i could use the wire taps, and shrink wrap.
any other ideas, im wondering if thre is anything i could use to tap into the wire at the pin connector ( at the clip) like somehting that slides into the pin slot or so .. any1 here know of any such thing? ( which requires no cutting or splitting of ecu harness)
