Hazard Relay
Hazard Relay
I have another typical issue: clicky relay. Is there any way to tell whether the problem is in the stalk or in the relay without replacing the latter?
Just started today, and basically the "relay" contiunues clicking from behind the hazard switch sporadically after I use the turn signal, hazards, or just a random tick every now and again.
Also, is the hazard switch the same thing? I thought ecs sold the relay, didnt find it but maybe it was because I was looking under 225 and they have it listed elsewhere. genuinevwaudi parts had this listed. Thanks
hazard switch, tt
00-06
$59.85
$0.00
$41.30
Electrical - Chassis electrical - Switches - hazard switch
hazard switch, tt
00-06
$59.85
$0.00
$41.30
RE: Hazard Relay
I guess that link doesnt work, bah. In any event I heard it was a pia, I havent done much on the car myself except pull the lower dash on both sides, install the boost gauge, and throw an intake on. Bout that level of difficulty? [8D]I seem to remember seeing the keys somewhere el cheap, like 5 bucks hmm. I know I can get mcgyver with file hanger tab but uh rather not.
RE: Hazard Relay
bahh, alright ordered the switch and the stupid $5 stereo removal key. weeeee, hopefully I can manage the swap, getting stuck halfway is not cool. also got the aux input on the way since my cd changer is starting to get flaky and not play all discs.
RE: Hazard Relay
ORIGINAL: randomloginname
theres a DIY posted on audiworld on exactly how to do it. looks pretty simple. search "hazard relay" on AW and you'll see it. i will probably use the same one when i get around to fixing mine.
RE: Hazard Relay
RE: Hazard Relay
Same symptoms I have. Relay didn't fix the problem. I'm going to need a new turn signal stalk.
Just for your comparison my symptoms are fast clicking after using the turn signal. Turning this clicking the turn signals dont light up, just sound from behind the relay. I also get sporadic clicking and random single clicks just driving down the road.
RE: Hazard Relay
Thanks for the heads up, my turn signals work front and back so I will try the switch since I already ordred it anyways haha.
RE: Hazard Relay
hmmm alright then I dont know. Might as well try it at this point, I asuume the stalk replacement is exspensive/pia? I am getting abs sensor, rear sway links, brake flush , tranny and diff fluid replaced this week already, I love the tt but gd. At least the maintenance wont have to be done again for years.
