have a problem need advice
well my car has been smoking color white from the exhaust with a bad smell sometimes not all the time when the car is at idle, however the car is running fine the turbo seems to be boosting fine.
i recently did a 3"dp and full 3" turbo back exhaust decat and deresonated any comments appreciated. the car has 135k.
well this thing has happened before the exhaust it happens maybe once every week especially after i drive the car hard. the thing is the car is running fast it is the fastest its every ran. do i need to start saving for T3T4 .
white smoke means burning coolant. possibly head gasket on its way out. when the engine is cold, take a look at the oil on your dipstick, if you see white streaks in the oil, that means there is coolant in it.
if it only smokes once in a while, just keep an eye on it, but if it starts to do it more often, i'd start planning on replacing the head gasket.
