Haladex service instructions
Old 04-01-2007 | 02:32 PM
Z06guy's Avatar
Default Haladex service instructions
Hi, my brother just boughtan '01 225 quattro TT with 60k miles. Yesterday we did the timing belt/ tensioner/ dampener/ waterpump/ service on the car. We have also already replaced the ribber belt and changed the oil. We also got the Haladex oil and filter, but when I finnaly found the filter in the car, I realized it was a job for another day. [] I have searched the website, but was suprised thatI could not find instructions on how to service this. I know there is a special tool, but I am just imagining a big star wrench for the filter. How do you drain the oil, get to the filter, and insert the new oil? Thanks.
Old 04-01-2007 | 02:34 PM
Grooby's Avatar
Default RE: Haladex service instructions
http://public.fotki.com/ttschwing/ha.../haldex-2.html
drain the oil from that hole and then pump the fresh oil back in.
Old 04-01-2007 | 02:43 PM
XCLR8TT's Avatar
You need a special wrench to get the filter off as well. You can get the VAG tool for around $70.00 (look for Matra T10066) or Modshack has a H-Wrench for $40.00
Old 04-01-2007 | 02:47 PM
Grooby's Avatar
or do what XCLR8TT do. Grab the filter by the hand, use your super human strength, and twist!
Old 04-01-2007 | 02:50 PM
XCLR8TT's Avatar
Ha ha ha, I wish it was that simple, there is even less room to get a hand in on that filter than there was to get the Haldex controller installed. I had a very difficult time just getting the two screws out of there and then wiggle the controller out. I recommend you get the wrench unless you have superhuman strength and child sized hands.
Old 04-01-2007 | 03:01 PM
Grooby's Avatar
shhh....did you hear that? I think someone is whispering "use the force.."
Old 04-01-2007 | 03:05 PM
Z06guy's Avatar
Thanks for the responses. So you can get to the fiter if you have the tool, huh? Wow, it looked like I could barely touch the thing, let alone get change it. Then you have to put the drain plug back in without all the new oil falling back out.... that does not sound fun. Can you reinstall the plug, then insert the oil through the filter opening before installing the new filter?
Old 04-01-2007 | 03:35 PM
techbod's Avatar
Changing oil filter for Haldex coupling
Special tools and workshop equipment required
t
Angled ring spanner -T10066-
Removing
Place drip tray underneath.
Slacken oil filter with angled ring spanner -T10066- and unscrew.
Fitting position: the oil filter -A- is located on the right side of the vehicle (covered by the subframe) near the front mounting bracket -B-.
Installing
Lubricate O-ring of new oil filter with oil for Haldex coupling.
Screw in oil filter -A- and tighten to torque with angled ring spanner -T10066-.
Check oil level in Haldex coupling ; if necessary, change oil in Haldex coupling
[IMG]local://upfiles/12092/F7490C15A46D47329D9B6D514F79CED0.jpg[/IMG]
[IMG]local://upfiles/12092/6A637C88990C43DFAC44F0238CBDD19B.jpg[/IMG]
Old 04-01-2007 | 03:37 PM
XCLR8TT's Avatar
It really isn't that tough to use the drain hole to fill it. Remember you are using a caulking gun to force the oil into the small drain hole. There is more than enough oil filled via the tube than would flow out through the hole. With the filter in place, the draining is very slow since it is unvented. You'll get a little bit of oil on your arm, but there will be more than enough left in the Haldex unit. Just have the drain plug stuck on the end of an Allen wrench close by, so when you pull the hose away you can fill it right up.
If you fill through the filter opening, you will not have a high enough level in the controller. The full level is near the middle of the filter opening.
Old 04-01-2007 | 05:07 PM
Z06guy's Avatar
Right on. Thanks guys. Excellent help!!! You will probably hear from me in the future about tracking the car and related mods. That's what's in this TT's future! Lucky car.
Chunkman00TT
07-17-2012 03:43 PM
acetrebo
03-19-2007 08:16 PM
tcuphigam
01-27-2007 06:29 AM
MeanAudiA6
02-08-2006 12:26 AM
MeanAudiA6
02-07-2006 12:03 AM
