Grinding from P/S Front wheel
Hey on acceleration from 2nd and 3rd under hard throttle I get a grinding sound on the P/S front wheel I was thinking either CV Joint or Wheel Bearing. The CV Boot is ripped that I need to fix. Any Ideas from anyone would be great.
Thanks
Jewbin
Thanks
Jewbin
RE: Grinding from P/S Front wheel
jack up that wheel so that its off the ground and give it a spin with your hand, listen and see if you hear any rough sound. It could be a wheel bearing, but if it is it should make a noise all the time not just from 2nd to 3rd gear.
Keep in mind the TT is known for a 3rd gear grind at the upper RPM range.
ORIGINAL: JewbinTT
HEY. Thanks. I will try that. Florence right? I dont think its the 3rd gear grind. Keep in mine I'm quattro. It is on hard take off 2nd and 3rd.
Thanks again.
Jewbin
Thanks again.
Jewbin
I just read your post again and saw where you said hard throttle. I would say to cange your tranny fluid, I'm waiting to change mine as soon as Pure Motorsport sends my fluid, been waiting almost 4 weeks... why did I have to order backordered spacers along with it [:@]
*Edit- 2nd and 3rd... hmm XLR might be right about the CV boot.
ORIGINAL: XCLR8TT
If the boot has been ripped long, you've likely thrown all the grease out and gotten dirt and sand in the joint. Sounds like you've already ruined the CV joint. Better plan on a new CV joint along with the boot. r.
ORIGINAL: JewbinTT
When I did my Timing belt I noticed the boot ripped. its been like a week since I did it. I think I will just replace the CV Joint. I did hear the terms inner and outter CV Joints is this true with the TT?
Thanks for the advice.
Jewbin
What does this tranny fluid do that other "standard brands" dont?
If there are improvements I might be very interested.
Since I just bought my car.
I'm planning in the next couple of months on replacing.
Fuel filter
air filter
cabin filter
tranny fluid
brake fluid
spark plugs
i just changed the oil, however i will be changing that when i do everything else.
any other suggestions? any suggestions on products and why? I remember somewhere that someone suggested different spark plugs because im modded.
any suggestions on which brand?
Fuel filter
air filter
cabin filter
tranny fluid
brake fluid
spark plugs
