Griding and Scraping Noise
Old 11-06-2008 | 11:07 AM
chris's Avatar
Thanks. Are the bearings (wheel and haldex) something I can check myself, or is this all something I should have a service shop look at? I'm not sure if it's my parking brake, because it's only coming from one side, and if I come to a stop, the car will still roll.
Old 11-06-2008 | 11:22 AM
jakej's Avatar
Yes. That is exactly how mine is. From what I understand, you need to either buy or find a place to rent a $400 tool to do the wheel bearings. You can check the wheel bearings by lifting the car and pushing on the tire at 12 o clock and 6 o clock. There should be no movement.
I have not heard of anyone doing the halidex bearing themself. The noise sounds like it's only coming from the rear pass side, on mine. I just dropped my car off at the shop, because I have a warranty. And they determined it to be the halidex bearing. I have not yet gotten the car back.
Old 11-06-2008 | 12:36 PM
hcaudikeed's Avatar
check ur lugs, i had my mechanic change the pads on my car n he mounted the wheel on wrong n caused exactly what ur saying. it could be the wheel rubbing against the caliper everytime the spot thats off (closer to the caliper) comes by. mounted it back on right n problem solved.
Old 11-06-2008 | 01:22 PM
chris's Avatar
Jake, that's the exact same place that mine's coming from. Unfortunately, no warranty, so out comes the wallet, I suppose.
hc, the rear wheels have been mounted since April. If that were the case, surely it would have occurred sooner?
Old 11-06-2008 | 01:26 PM
chris's Avatar
Originally Posted by jakej
See my post: Parking brake stuck on / fluid leak. I'm having the same issue now. It appears to be the halidex bearing.
Ps. it's not going to be the brakes if the noise doesen't change when you apply the brakes. I also don't think a rock stuck somewhere is going to cause a loud noise for several miles. I would guess your problem is either the same as mine or a wheel bearing.
Oh, and the noise does change when I apply the brakes. It becomes much louder.
SilverSurfer01
01-19-2012 03:52 PM
mazc00
Audi Q5
05-04-2011 01:38 PM
yohan
06-01-2007 09:33 PM
SMU09
05-05-2006 01:38 AM
sandman
08-31-2005 09:19 PM
