Good offset for TT wheels???
Ive been looking for wheels, either black or gunmetal, for my black TT and I want to know a good offset that will keep them flush with the body and where to get them?? thanxxx
RE: Good offset for TT wheels???
http://www.2x.ca/TT/offset/
Within reason any wheel can be made to fit flush with spacers. You do need proper bolt pattern. 5/100
ORIGINAL: xTTx
have you ever had issues or heard of anyone having issues when using spacers?
so I should subtract 8mm from what the calculator said i should get then? but the front is the same though right? if that is right then i should get a 22mm front and 20mm back, is that too drastic? Im not looking to cause more problems for myself in the future just to get my wheels to look wider is my point i guess.. thanks for the help.
ORIGINAL: xTTx
Mine are 8in w/ a 35 offset. I am fwd and run 20mm in the front and 25 in the back and the wheels set great.
i bought some wheels for the time being for pretty cheap used until i can find some that I like and will fit. they are 17x8 38mm.... and im running 225/40/17 i believe and ive got a 2000 180 fwd...
capn
11-14-2012 05:34 PM
mafagan
04-18-2008 01:33 PM
