full or empty?
Old 07-24-2008, 09:13 AM
savagebeast's Avatar
Default full or empty?
I got im my car 2day and I know it has a 1/2 a tank of gas, it was over f! so I stoped a few blocks down and shut it off and started it up again, now it said 1/2 tank, 5 min later it was full again. I know its not the gas gods showing me love! any ideas?
Old 07-24-2008, 09:42 AM
XCLR8TT's Avatar
Default RE: full or empty?
Try running a couple of tanks with Techron added, it may be that the fuel sensor contacts have sulphur deposits on them. If that doesn't help it is most likely a problem with the in tank sensor itself or the cluster.
Old 07-24-2008, 09:50 AM
thanks would autozone have it?
Old 07-24-2008, 10:12 AM
.clipse's Avatar
SoCal Crew Member
^ ive ran a few tanks w/ techron and no dice.
mine's def. a cluster problem since usually, half a tank means empty for me
Old 07-24-2008, 10:56 AM
And i bet theirs no way to just replace the gague? Anyone know of an aftermarket digital unit that would have all the readings needed?
Old 07-24-2008, 11:00 AM
I ment is their a digital unit that would replace the stock gague clusterand have all the reading I need?
Old 07-24-2008, 01:15 PM
jakej's Avatar
dam forum is broken!.... anyway, no aftermarket fix. Yours sounds like the sensor in the gas tank.
Old 07-24-2008, 01:34 PM
So if the fuel additive doesn't work then how hard is it to replace the sensor and how much$?
Old 07-24-2008, 05:55 PM
chris's Avatar
I must be one of the lucky ones. My gas gauge always reads Full! Screw you, corporate America! I don't need your gas!
Old 07-24-2008, 06:56 PM
jakej's Avatar
There are some how-to's online, just search. It sounds pretty easy. I think its less then $300 too.
Quick Reply: full or empty?
