Fuel Gage
Old 10-15-2010, 08:27 PM
TTeriffic's Avatar
Default Fuel Gage
2001 TT with fuel gage that is very sporadic. Seems to settle down when reading less than 1/2 full. Any thoughts? Sender difficult to replace or possibly gage malfunction?
Thanks.
Old 10-20-2010, 07:48 PM
trackstar6's Avatar
The gauge cluster is a known problem with these cars, mine does the same thing. I just pretty much make sure it stays full or close to it
Old 10-27-2010, 01:04 PM
hdgroundpounder's Avatar
Trackstar6, does your gauge needles bounce around or flicker when you start your car? My son and I bought a 2001 Quattro, 64,5K miles and when he starts it in the morning the gauges act funny then it seems like they reset and everything works fine...gas gauge is odd like you say...but trip odometer and clocks zero out! Let me know!
Old 10-28-2010, 09:04 AM
coachvtt's Avatar
I have the same issue with my gas gauge as well now for the other needles or trip
odometers they work fine for me for how long who knows.
Gauge cluster not cheap and PITA to replace.
Old 10-28-2010, 11:32 AM
cincyTT's Avatar
I'm make believe
I have a spare cluster im trying to get rid of. The fuel gauge works to my knowledge along with all the LEDs. Let me know if you are interested.
Old 10-30-2010, 08:14 PM
trackstar6's Avatar
I haven't had any issues with my odometer just the temp gauge and gas gauge. Also my car has about 80k on it and it already on its 2nd cluster which is failing. (first was replaced at 27k under warranty)
Old 11-02-2010, 11:28 AM
TT is in the shop! Since we bought it less than a week ago from the Audi dealer they are working on the instrument cluster.
Since there was another recall on the timing belt I am have them install a new one with water pump. It was inspected per the law suit at 55K miles but really need the car to perform well now without any mishaps. Figure I'd put a few bucks into it.... good little car so far, other than the Gremlins!
Greg
Old 11-03-2010, 08:59 PM
Default update
Timing belt, water pump and tensioner done. Dashboard replaced! Total bill today $1325.00 I guess a small vrs replacing an engine.
Old 11-04-2010, 12:09 PM
Scigano's Avatar
I've recently picked up a 2001 180Q and I've noticed my fuel gauge can change slowly sometimes with my driving style. It doesn't bounce or change sporadically, but after a few pulls, it can start to drop, but if I take it easy afterwards, it goes back up a bit.
I'm mostly concerned about the issue I heard where the gauge reads 'half empty' but in actuality, it's much closer to empty - as a result, I've never let it go further than a hair past half before filling up.
By "half a tank" I've gone 230 or 260 miles and typically put in between 9 and 11 gallons in. I'm skeptical to that being actually "half-a-tank"s worth of distance (460 to 520 miles on a single tank?! - my last car was a Miata which was typically dry by 220 miles) I'm not sure what a full tank of gas hold on a TT 180Q, I've been told a little of 16 gallons by some, 14 gallons by others.
Old 11-04-2010, 12:45 PM
trackstar6's Avatar
The 180's have a 14 gallon and the 225's have a 16.4 gallon
Quick Reply: Fuel Gage
