Front End Popping?
Front End Popping?
I notice sometime when turning lock to lock...mainly at slower speeds... That I hear some popping noises from the front end. My first conclusion was that it was the haldex system. Much like when an SUV is in 4 Wheel Drive and the wheels are at different speeds. One post I found while searching offered the same answer.
But is there another answer? I know it's a vague description, but I'd hate to go along thinking one thing then find out the hard way that it was a different front end component...
RE: Front End Popping?
i just started to hear this so i ordered the strut bearing and perch replacement kit from ecstuning.com i'll be doing this install sometime next week so i'll be sure to post the results
ORIGINAL: MeanAudiA6
That is the most likely culprit. The strut bearing and bushing do wear and exhibit the popping, clicking noise when you turn at low speed.
http://www.ecstuning.com/stage/edpd/...productID=5029
?? Thanks!
yup thats what i ordered
I doubt it's tough, at all, but a heads up is always nice.
