Front end clunking noise
Old 11-07-2008 | 03:07 PM
jhsoccerodp's Avatar
Default Front end clunking noise
When i am pulling out of a parking space every-time i go from r to 1st i get a clunking noise but it not when i shift its when the weight shifts and it sounds horrible. Also when i stop at low speeds i hear a squeal from the brakes, ive used brake quiet but that doesn't help. Cheap pads maybe? or wheel bearing? Any thoughts on either?
Old 11-07-2008 | 04:14 PM
warranty225cpe's Avatar
is the clunking sound every time you go from forward to reverse? Or does it happen more often when your turning the wheel going from forward to reverse? I've had the same issues with my 04 coupe. Since I'm still under warranty, I've brought it in atleast 6 times for that same issue. Needless to say, EVERYTHING in my front end has been replaced for free. I brought it in last time, and road with the service manager to duplicate the problem. He verified that the noise still existed. They have come to the conclusion that the noise is caused by "steering rack bottoming out on the bumpstop. I'm not sure if they are right or not.. What I do know is all of it is new, but of still makes that ****** noise!
ericcota2003
04-01-2010 01:52 PM
der Lump
12-16-2009 10:55 PM
AirMax95
11-02-2008 10:12 PM
MagnusBL
06-08-2007 04:40 PM
Audi_Skydiver
03-07-2007 04:10 AM
Quick Reply: Front end clunking noise
