Forge 007 owners!!!
Old 10-08-2007, 08:52 PM
225tt's Avatar
Default Forge 007 owners!!!
Just wondering what spring and or shims your using and how much boost your running? Thanks!
Old 10-08-2007, 09:26 PM
Ergokinetics's Avatar
Default RE: Forge 007 owners!!!
Yellow spring, no shim, 22psi.
Old 10-08-2007, 10:58 PM
.clipse's Avatar
SoCal Crew Member
yellow spring, no shim, 1.1 bar
Old 10-09-2007, 12:10 AM
225tt's Avatar
Thanks, I cant seem to get to 22psi with the yellow spring it keeps studdering onceI reach 19psi? I am running the boost machine, anyone have any ideas?
Old 10-09-2007, 12:21 AM
cincyTT's Avatar
I'm make believe
start off with a shim and see how that goes. I think andrew runs it that way with the same setup
Old 10-09-2007, 12:48 AM
225tt's Avatar
Thanks will try it tomorrow and let you know how it turns out.
Old 10-09-2007, 10:17 AM
MeanAudiA6's Avatar
yup yellow spring and one shim
Old 10-09-2007, 11:33 AM
225tt's Avatar
Thick one or thin one?
Old 10-09-2007, 12:15 PM
MeanAudiA6's Avatar
ummm i thought they where all the same size thickness hmmm try the thicker one if your running more than 20psi i keep mine around 20psi
Old 10-09-2007, 02:10 PM
225tt's Avatar
Thanks will try it....
Quick Reply: Forge 007 owners!!!
