fast slow rpms... weird
Ok here is the deal now guys. When the car hit boost in the 3 throw 5 the tach some some crazy stuff it jumps up alittle then comes back and stuff im not sure if my clutch is slipping ot if my gauge cluster is taking a crap need some help as allways.
RE: fast slow rpms... weird
but they fly forward and then goes back like it is grabing then goes up. but why would it no do it in 1st and 2st when the torque is the highest? the car only has 32000 miles on it to.
tq is higher in 3+ gears. Also you are not going to see the same psi in those gears as you will in 3+. It sounds to me like its at the begining stages of the clutch going out.
is this when you accelerate hard, normal, or even slow?
its when i put it to the floor starting at about 2800 rpms. look at the rpms in the vagcom with it help me figure it out? i mean if they sre screwie in the computer than it is the cluth and if they are on Q then it is the cluster ?
