Extra money. - What to do for mods. - I need YOUR help! - I'm confused!
RE: Extra money. - What to do for mods. - I need YOUR help! - I'm confused!
i will sell you my hyperboost DV for 75+ship... its only like 3 months old... im selling it for a BOV.. you can find it at stratmosphere.com and its annodized blue.. its a good DV IMHO.
once you get a DV get an mbc(manual boost controller) so you can up your boost a bit.
water/meth injection allows more boost too which is good stuff right there.
What kind of DV is it?
Whats the difference between a DV and a BOV - Blow off valve?
- That noted... will the dv from APR make the " pssh " sound. - or is that just the blow off valve?
With the APR chip im using now (93+ oct) - Does anyone know what boost im running?
What can the K03 turbo handle? - How much wear will it put on it...by upping it? - Note - I would like to up to a K04 turbo in the future if I can find a good deal one one. - I've been looking for a wrecked 225 ...so I can get all the engine goodies!
The new dv wont be much louder as the stock one. With it also being a diaphram dv, it should sound roughly the same.
Most Hyperboost dv's are piston dv's like the forge007. I really think that you need one that you can install and forget about, thats why the apr is good for you.
Water/meth will lower intake temps, raise octane, clean the cylinders, and reduce knock. This allows you to increase timing and boost since its like running ~110octane on 93 pump. The only negative is that you have to refill it.
As for how it works, you tap into the MAf or the Map (Maf is better, proactive vs reactive on a map) and it will start spraying at a set boost level and then fully spray at max boost. So it only sprays when it sees a certain voltage (maf) or boost (map). Most containers (most us ww resivour) last about 2 tankfuls.
ORIGINAL: bmwtoaudi
Most fwd cars are making 230-240whp and 280ftlbs with a ko4-22/23, not sure on boost level, but should be low 20's
#18
ORIGINAL: cincyTT
nope, those are totally differnt. WOnt fit 180Q either, would hit the transfer case
#19
Well, not when it comes to traction. But nothing a BIG turbo wouldnt cure with some lag. With a FWD car, high hp is better than monster low end torque.
