Err code driving me insane, HELP!
Please help, my cruise control function isnt working anymore and I drive long way to work. It is driving me insane. Please help. I thought it would be the break light switch(I had a code for this as well, but upon changing the switch, I erased the code) but even after I changed the switch, the cruise control isnt working. Please help. I vag'd and found these codes. I erased them and keeps on coming back.
2 Faults Found:
17977 - Cruise Control Switch (E45): Implausible Signal
P1569 - 35-10 - - - Intermittent
17521 - Shareware Version. To Decode all DTCs
P1113 - 35-10 - Please Register/Activate - Intermittent
What is Cruise control switch? does this mean switch is bad and I should change it?
and I dont know what 17521 is.
Only mode I have on my car is GIAC. cruise control was working fine after the GIAC chip.
Mine is 2000 180Q TT.
Please help, Please it is really driving me insane.
2 Faults Found:
17521 "Bank1-Sensor1 Internal Resistance too High" Would this by any chance cause the 17977 cruise control switch error by anychance?
One thing I noticed is that while driving, as soon as I click the cruise control switch to "on" position, the 17977 error msg comes up on the vag-com.
Can anybody please help me out here?
Would having an faulty hazard switch threw a cruise control switch code?
2 Faults Found:
2 Faults Found:
If you still have access to vag-com read measuring block 066. The 4th section of that channel is the curise control switch status.
0000 = Cruise control switched off (switch engaged)
0011 = Cruise control swtiched on
0001 = Cruise control switched off (switch not engaged)
0111 = "SET/FIX" button pressed in
1011= Switch moved to "RES/AUFN" ("resume") position
This will at least let you know if there's a loose connection somewhere, or if the whole switch is bad. I seem to recall a few TTers replacing their cruise control stalk.
