Engine Noise
Old 05-15-2008 | 05:10 PM
PaTTy225's Avatar
Default Engine Noise
I have been searching the forums but can't find anything related to my problem.
Recently, when I start up my TT if it has been sitting for a few hours I get this loud and abnoxious ringing noise that sounds like its coming from my engine. It lasts for like 5 minutes and then shuts off.
Anyone know about this?
Old 05-15-2008 | 07:09 PM
ouTTie914's Avatar
Default RE: Engine Noise
What's the outside temperature like when this happens?
Old 05-15-2008 | 08:14 PM
Schroeder's Avatar
I think it is just the raspy stock exhuast when cold starting the car.
Old 05-15-2008 | 08:53 PM
Hitchr10's Avatar
WD-40...fixed
Old 05-16-2008 | 10:00 AM
PaTTy225's Avatar
its been warm actually....i never had the problem when it was cold out......its like a real high pitched squealing noise at startup
Old 05-16-2008 | 01:37 PM
randomloginname's Avatar
SAI?
Old 05-16-2008 | 02:44 PM
PaTTy225's Avatar
I was wondering about that....can it be fixed
Old 05-16-2008 | 02:53 PM
Mine isnt broken, just noisy until the car wramps up/rpms drop to ~900. If y0ou dont like it, turn off your climate control (pull the **** to off) before you turn car off and then dont push it in until car is warmed up. I guess yo ucould/should check to see if you are throwing any codes.
Old 05-16-2008 | 05:18 PM
PaTTy225's Avatar
thanks ill try that
Old 05-16-2008 | 06:25 PM
cincyTT's Avatar
I'm make believe
Its the SAI, it is normal and will be that way until the car is warmed up.
jraffoul
04-10-2017 07:10 AM
kenman
09-12-2012 03:34 PM
tj19855
12-31-2007 04:28 AM
tbrown
09-11-2006 03:47 PM
