Engine misfiring throwing codes
Old 03-27-2008, 09:26 PM
Inibalir's Avatar
Default Engine misfiring throwing codes
Hi, I got a bad misfire and a flashing check engine light. Codes are P0300, P0303 and P0304 pd. Which means general misfires and misfires detected on cylinders 3 & 4. Anyone know what would cause this? Coil?
Thanks in advance for all the good advice you all always offer!
Inibalir
Old 03-27-2008, 09:30 PM
cincyTT's Avatar
I'm make believe
Default RE: Engine misfiring throwing codes
swap coilpacks 3&4 with 1&2 and if the misfires continues in 3&4, its the plugs, if it moves with the packs, its the packs.
They go 1-2-3-4 from passenger-> drivers side
Old 03-27-2008, 09:34 PM
Inibalir's Avatar
Wow, that was fast. Thanks! I'll check it out tonight. Never have touched the coil packs. Easy to get to?
Thanks!
Inibalir
Old 03-27-2008, 09:35 PM
cincyTT's Avatar
I'm make believe
Just pull the cover off with a flathead or keys and then if you have the push downs, you just pull the tab and swap them. If you have the bolt downs, you will need a 5mm allen to get them off.
Old 03-27-2008, 09:37 PM
Inibalir's Avatar
Great! Thank you I really appreciate it.
Old 03-28-2008, 05:29 AM
monkey323i's Avatar
Just Vag-com scanned my 3.0L B6 tonight.
I got two codes.
P0300 -Random/Mutiple Cylinder Misfire Detected
P0305 -Cylinder 5 misfire
I just replaced spark plugs 2 weeks ago.
What causes this problem? Coil pack?
Old 03-28-2008, 08:36 AM
quattro411's Avatar
sounds like the coil packs, if so you should replace them all because they prob aren't the most recent part numbers
common failure
Old 03-28-2008, 09:38 AM
jkobs's Avatar
I just had this problem with my TT. I replaced the coils with STI ones, and I still had the problem so I had to get some new stock ones.
Old 03-28-2008, 11:53 AM
cincyTT's Avatar
I'm make believe
I just hope people check plugs/gaps and swap packs around before dropping a $30+/pack that may not be the cause.
Old 03-28-2008, 12:30 PM
Inibalir's Avatar
Well, I swapped the coil packs and I'm still getting the same codes.
Quick Reply: Engine misfiring throwing codes
