ecu Removal Help
Old 07-08-2007 | 08:16 PM
holyshiznets's Avatar
Default ecu Removal Help
Im trying to remove my ecu of my 02 tt Quattro..
Is it normal to have a piece of black metal around my ecu and the right wiring harness so I cant unplug it?
I got the left wiring harness off and couldn't get the right one off so I slid the whole ecu out still attached to the right wiring to see what the problem was
Not sure if you can see anything but this is the right wiring harness with the metal over it
http://img223.imageshack.us/img223/7239/ecuam6.jpg
Old 07-08-2007 | 08:37 PM
AudiOso's Avatar
Default RE: ecu Removal Help
You need to remove the security screws to get the bracket off. Here's a link to an APR instruction sheet on the B6 A4 that shows how to remove the security screws. They are a royal pain in the tush to get off. I used a small pair of vise-grips and turned them off. Good luck.
http://www.goapr.com/Audi/support/ecu_a4_b6.pdf
Old 07-08-2007 | 09:39 PM
yeah thats it thank you..
I dont exactly have the proper tools to do it though..
Ill try to figure somthing out
thanks again
Old 07-08-2007 | 10:48 PM
WishIWasRWD's Avatar
I'll be doing this tomorrow, I started tonight but I ran out of light.
I don't have a cut-off wheel available, so I have to figure something out.
I'll let you know If I figure out a decent way to get them out.
Old 07-09-2007 | 01:15 AM
theTTkid's Avatar
i had to do the same and... i just cut a line in the security screws so i could fit a flat head in...
Soley4pres
07-12-2011 12:58 AM
99a4wagon
12-10-2010 08:03 PM
halfmoonclip
B8 Models
01-09-2010 10:48 PM
nhltfour
04-22-2007 03:23 AM
MeanAudiA6
08-06-2006 05:57 PM
