DV flutter
Old 03-06-2010 | 09:03 PM
moeron7's Avatar
Default DV flutter
Sometimes when i let off the gas pedal slightly i can hear my diverter valve flutter instead of just a clean release. But other times it doesnt do it. Do i need a stronger or weaker spring or should I shim it or is this normal? Thanks in advance.
Old 03-07-2010 | 03:30 PM
cincyTT's Avatar
I'm make believe
You have a single spring that is set for peak psi. When you are part throttle with less psi, its going to be stiff. This is normal and why HKS makes a ssqv and other companies make dual stage valves.
Old 03-07-2010 | 07:52 PM
moeron7's Avatar
good to know. thanks cincy
bob1
02-10-2021 12:03 PM
makav3li
03-24-2010 11:10 PM
rlubbers
04-23-2009 04:48 PM
holov
06-05-2007 08:23 PM
kaklexicon
07-15-2006 01:37 AM
Quick Reply: DV flutter
