Drifting?????
Old 02-21-2006 | 03:42 AM
teamgreen98mx's Avatar
Default Drifting?????
Hey guys I am starting to wonder if maybe my quatro isn't working right. I didn't think anything of it untill again my back end broke loose and started a powerslide around the corner again. This is the second time that this has happened. Both of the times were around 50 mph. Is this normal or is that just plain too fast for the Quatro TT. What do you guys think?
Old 02-21-2006 | 03:45 AM
socalaudi's Avatar
Default RE: Drifting?????
How sharp of a turn? I broke my *** end loose at 100mph. I thought I was going to die.
Old 02-21-2006 | 04:01 AM
wow Thats pretty fast when your *** wants to pass the front. haha Well both of my times were about 90 degree turns so they were pretty sharp. They were both at about 50 mph and the two different people on being a girl in the car just about sh@# them selfs. I was like wow that wasn't supposed to happen.
Old 02-21-2006 | 05:24 AM
Cameron's Avatar
Not to go off topic, but maybe you should reconsider taking pretty sharp 90 degree turns at 50mph Quattro or not. Especially when you have people in the car with you.
Old 02-21-2006 | 10:58 PM
achTTung's Avatar
ditto.
and yeah, regardless of which wheels are being driven, a 90° at 50mph will probably make your car do something you didn't want it to do.
Old 02-25-2006 | 02:21 AM
lowttfm's Avatar
sorry boys mine just grips and goes around corners 01 tt quat with 19axxis wheels nitto 555 and a koni shock and strutt system will do that for u.
one question u breakin em loose wiith the track cont off?
If so how often do u drive with the esp off because i def notice i power increase with it off but don't kno if it is unsafe for the cars health to drive with it off all the time.
Old 02-25-2006 | 02:35 AM
socalaudi's Avatar
I was breaking loose w/ 18 Rs4's and the quattro system. I was just pushing my luck. Plus Ive got stock sport suspension bridgestone so3's and an a4. If I had a little tt Im sure I would have stuck like glue. I was racing my uncle in his boxster and he only slowed down becuase he saw my slide, but his car handles great with the mid engine set up.
Old 02-25-2006 | 03:53 PM
achTTung's Avatar
Driving with ESP off is fine, its putting all the driving back on you, instead of the car doing all sorts of little corrections behind the scenes.
Basically, the car knows how far you have the steering wheel turned, and it also has yaw sensors and some other technical stuff, if it doesn't think you're turning as much as you want to, it uses braking on individual wheels, as well as some engine management i believe, to make the car point where you want it to.
So, you're probably saving on brake wear and tear if you're doing any aggressive driving with the ESP off.
S2Fan
10-16-2009 03:57 AM
masteroc
09-12-2007 03:38 AM
tank8970
02-03-2007 07:10 AM
noIQ
05-23-2006 08:37 AM
Toff_the_Toffee
11-09-2005 03:05 AM
