does the O2 sensor spacer cause any problems
Old 08-25-2008 | 09:39 PM
TTsteve's Avatar
Default does the O2 sensor spacer cause any problems
I am getting an intermitant cel light for my highflow cat and might do the spcer mod but want to make sure it wont affect any readings with the ECU.
Old 08-25-2008 | 09:45 PM
cincyTT's Avatar
I'm make believe
that o2 sensor only tells the ecu if the cat is working. If you get a spacer, it will make the o2 tell the ecu that it is
Old 08-25-2008 | 09:53 PM
TTsteve's Avatar
Thanks I had heard that it might change some air/fuel readings.
Old 08-25-2008 | 10:11 PM
MCPaudiTT's Avatar
The first O2 (pre-cat) is used to measure combustion efficiency (lean/rich) and make adjustments. The second O2 (post-cat) is ONLY a CAT-Health-meter, as cincyTT says.
Old 08-25-2008 | 10:21 PM
TTsteve's Avatar
cool thanks
Old 08-25-2008 | 11:30 PM
Mobius97's Avatar
They are right the 2nd is more of a "tattle tell". I was running my 3" hi-flow cat and STILL threw a CEL after a couple of months. Even tho they said it wouldn't. I kept clearing them but consistently would throw a cat below effeciency code. I took out the cat examined it and found no issues, cleaned the sensor but still had issues. I said screw it and threw in the test pipe with an arrestor.....still no luck. Eventually I just ditched the arrestor and attached the sensor to the bung.
I haven't even bothered with replacing the sensor tho...oh well.
Boystaysin
01-06-2014 10:01 AM
HermanL
B7 Models
08-16-2010 08:07 AM
grelazauto
05-14-2010 12:51 AM
MA3.0
03-26-2009 03:28 PM
01TT225Q
09-02-2008 05:57 PM
