DIY - N249 Delete
DIY - N249 Delete
http://forums.vwvortex.com/zerothread?id=4048354
Just wrote this up and wanted to post it for anyone interested
The resistor will get rid of one code, but you need a code in your chip to get rid of the other code if im not mistaken.
The n249 is like a backup to control boost. The ecu can use it to open the dv and lower boost pressure. If you remove it, you will have a smoother running car since the dv will be 100% closed. Of course it recommended that you use good boost control when doing this.
i followed the vortex one but as its for a 180 model i had to figure most of it out by myself which wasnt too hard....good to see one for the 225....now u need to do the EGR block off plate and remove the SAI pump
Is that something that a vagcom can handle or revo/apr/uni?
