detonation issues
detonation issues
I installed the BM (modshack)yesterday along with all the other stuff (4bar, etc..), and I started to immediately have detonation issues, no matter how much or little the boost was turned up..and I know this isn't supposed to happen. I took the BM off and detonation issues stopped...any ideas what would cause detonation just because boost was increased...yes, it was installed correctly
RE: detonation issues
the testpipe wont throw a code for 100+ miles if not spaced out or tp code in the chip. not sure why you have an issue with your BM, try a laxitive. Try removing the **** and 4bar, reset the ecu and then install the BM.
I can't reset the ecu without going to the performance shop and having them mess with the APR 91 program I have in it now..but at least I know for some reason everything works fine until I increase the boost..it's gotta be a fuel, air, or fuel/air mixture issue..this is where the bitch is, finding out where in the hell the problem exactly is..but I think i'll take the advice and at least remove the 4 bar and **** and run the bm and see what that does..
ORIGINAL: cincyTT
resetting the ecu just takes undoing the neg part of the battery for about 10mins.
Just got back from a few test runs..ran it w/o boost controller and detonation/fluttering/whatever you wanna call it kept happening..so i ran it w/o any modshack whatsoeverand put back 3bar stock fpr and airbox...no detonation issues whatsoever...so then i run it with just the 4bar (no **** or BM), and as I expected, detonation starts to happen again, everytime in 3rd or 4th gear at max boost and about 4-4.3 rpms
Now I'm gonna go run it with the 3bar back in place and the **** (BM still off)on and see what happens. but my suspicion is the 4 bar fpr is the problem. Think this is just a bad fpr?
Might have to do that...I'm using the 4bar from modshack. In any case, it ran fine w the ****, stock 3bar and n75..so the issue logically lies with the 4bar. I might just run everything stock now...with the mods I've done so far I'm pushing 20psi w/o a boost controller. I know it seems high but I did several runs with no modshack and it consistently pushes 20psi..hmm
