Decisions Decisions ......
A turboback is a downpipe and a catback, they dont have to be purchased together or the same brand. Calling it a turboback means your entire exhaust is changed. As for power, both are seeing between 7-10whp and about the same if not more in wtq. As for the ic, you will maintain your peak numbers since you will always be able to cool the charge far better since you wont have any heat soak and can often times increase the timing with it. Just to give you an idea, i made 197whp and 292wtq one run and then it dropped to 190whp 258wtq on the next due to heat soak on the stock core.
lennyauitt- i just went and checked out the turboback exhaust systems...first off they are very nice, the one i looked at was made by APR and it will set you back around 2,400 dollars. Basically your given every thing from the custom downpipe straight off the turbo, highflow cats....its all nice if you can afford it, im in college so the money is in small quantities haha
ttkid sorry bout that misunderstanding, i was looking at a system for a 225 from apr that gave you everything, ur way of just goin out and gettin each separate component seems to be the more logistical way of doin it
#19
Wow. So that's why they call u Tmoney!!! That's rather spendy for this kid!!! Ill just stick with my 3'' downpipe plan !! and sometime a chip! I just don't know where to go and ''flash'' it.. Or whatever u do to it??
#20
tmoney... check out ttstuff.com for the downpipes...
and then anything from a borla, to magnaflow, to blueflame, to custom catback will put you the rest of the way and far cheaper...
i just have a 3'' dp into a 3'' exhaust dump, then if i want i can just close the dump vavle and its an OEM exhaust...
