CRUISE CONTROL not working
RE: CRUISE CONTROL not working
sometimes its just dirt, it doesn't have to be bad. I get a code occasionally about an implausable signal for the brake switch. Basically, whats happening is that the brakes are applied, and the car sees that, but it takes more pressure on the pedal to get the brake light to activate. ECU gets confused, throws a code, I clean it, and I'm good again for awhile.
indicators blink several times and then stop working? hazard warning relay sounds like a new one is required cruise wont work if that's out because it all part of the safety system so try fitting a new one
Here's a good How To from the guys over at AudiWorld..
http://forums.audiworld.com/tt/msgs/1193292.phtml
#18
got the blinkers fixed from audi 190$ then they hooked the computer up and told me a further 420$ to fix cruise control.....The car is running rough ever since i got it back , I think it had something to do with hooking the computer up to it .Have cleaned maf sensor and still running rough. Any ideas?
#19
so you paid all that cash for them to create another problem which is their fault??? take it back and complain to the manager and get them to fix it for free, I honestly don't know how those sods sleep at night with doing shoddy work like that its what gives them a bad name and not good enough[:@]
#20
They say its the maf sensor. I followed instructions from the net on how to clean sensor and i did that 2 months ago.Anyway its covered under warranty so it will be free.Anyone know the best oil to use in motor 225hp ?I live in AUS/melb.
