CRUISE CONTROL not working
Old 01-29-2007, 05:32 AM
lopez371000's Avatar
Default CRUISE CONTROL not working
Hi fellas , my tt 225 roadster is an awsome car but my cruise control for some reason has stoped working.
Check fuse box but theres no fuse under cruise control.
Any Help?
Old 01-29-2007, 01:55 PM
bmwtoaudi's Avatar
Default RE: CRUISE CONTROL not working
My cruise gives me trouble because my clutch is slipping, but thats replaced today
Old 01-29-2007, 03:30 PM
XCLR8TT's Avatar
Could possibly be the brake switch or clutch switch.
Old 01-29-2007, 09:07 PM
I had my clutch pedal fixed because it stayed to the floor.
I guess that might have something to do with it
Can someone tell me how i can see if the switch is connected?
Old 01-29-2007, 09:18 PM
XCLR8TT's Avatar
It's at the pivot point of the clutch pedal. You may need to drop the lower dash piece to see it.
Old 01-30-2007, 06:31 AM
i tried to take the lower dash piece off but was a strugggle. Couldnt get it off but i saw an electrical connection going to the clutch. It was connected , could this be it.
if not some directions to taking thedash off wouldbe great!!!!!!!!!!!!!
Old 01-30-2007, 06:51 AM
Removing driver's storage compartment
1-
Driver's storage compartment
t
Removing
Unclip left dash panel end trim
Unfasten bonnet cable in passenger compartment
Unscrew bolts -2- (3x).
Unscrew bolts on side
Pull driver's storage compartment -1- out of clips -4- (3x).
Pull mounting frame outwards to side.
Set down driver's storage compartment.
Unplug connector to rotary light switch
Squeeze fasteners -5- (3x) and unclip diagnostic connector -6-.
t
Installing
Guide holder -3- into mount at pedals.
2-
Bolts (3x)
3-
Holder
4-
Clips
5-
Fasteners
6-
Diagnostic connector
Unscrewing bolts on side
Unplugging rotary light switch connector
Press retainer tabs -arrows- and unplug connectors -1- and -2-.
[IMG]local://upfiles/12092/DD8FE5EF81654A9D9C8B0CD53C80D876.jpg[/IMG]
[IMG]local://upfiles/12092/42EB5867BA1543F48DEF47559E9F256C.jpg[/IMG]
[IMG]local://upfiles/12092/8B42ED8E0E9749D890E9279566AC1C76.jpg[/IMG]
Old 01-30-2007, 06:58 AM
if the idle or RPM at speed is unstable it will turn off the cruise and that goes for breaks like a bulb out is seen by the ECU as you pressed the break peddle
Old 01-30-2007, 07:08 AM
just did some reading on the cruise and apparently its run by the ECU so it needs VAG to check for problems and even to turn it on
Old 01-30-2007, 06:02 PM
Euroluv's Avatar
this has happend to my 02 225 coupe. i took it to a shop and they say that the switches are known to go bad or they will just start working again. but i just decided to wait it out and about 2 weeks later it just started working again..
Quick Reply: CRUISE CONTROL not working
