Crankshaft Position Sensor?
Old 09-15-2011 | 01:27 PM
mikestt's Avatar
Default Crankshaft Position Sensor?
My TT stalls after 25 mins of running at idle. It cranks when it is hot and won't start back up until it cools down. I have replaced the fuel pump, fuel filter, spark plugs, all coils, and tried a new camshaft position sensor. None of which has worked. I have checked for vacuum leaks and have found nothing. Could this be a crankshaft position sensor problem? Has anyone had similar problems with the car stalling after it has warmed up only to restart after cooling down. Thanks for any ideas!
Old 09-24-2011 | 11:21 PM
ericcota2003's Avatar
I had this exact problem 2 years ago. It was definitely the crank position sensor for me. I had the same problem. Car would start run for about 15 20 mins then stall and not start until dead cold. I went through any thing and everything because I couldn't get it to throw a code. I paid I think around $100 for a replacement through auto zone.
Old 09-25-2011 | 05:35 AM
mikestt's Avatar
You are dead on ericcota2003! I replaced the CPS this week and the car is running fine. Although it was really hard to get to and it took a few hours. I got my replacement at Advance Auto for $89. You can google some promo codes for Advance Auto and get up to 30% off your total order. Thanks for the input.
Old 11-29-2012 | 12:09 PM
coachvtt's Avatar
Default location?
Where is the cranshaft position sensor located on the TT 225?
Old 11-29-2012 | 06:12 PM
ECS Tuning's Avatar
Sponsor
It should be located near oil filter hosing.
Jason
vpinargote
09-10-2011 11:53 PM
JPizano23
06-16-2011 08:25 PM
Piperalpha
08-19-2010 12:46 AM
Hotdog
03-19-2010 12:50 PM
mcinp
01-03-2008 10:49 AM
