Cooling fans Wont trun ON
RE: Cooling fans Wont trun ON
Do they turn on when you have the AC on? If not its the fan control module.
After you replace that and they turn on with the AC on your next step is to run the car with no AC and at idle let the temp increase. At 104/105 the fans should kick on to high speed. If this doesn't happen then your thermoswitch is out too.
If you replace the fan control module and the fans dont turn on with the AC running then its a good chance the fans are shot.
