Coolant Leak
Old 11-10-2010 | 11:23 AM
BreezeThe TT's Avatar
Default Coolant Leak
Trying to figure something out....If i dont have the car on and i put coolant into the car and it runs right out is it possible that its leaking from the water pump...Or does the car need to be on before it reaches the water pump?
Old 11-10-2010 | 12:10 PM
beachchair's Avatar
Check your coolant flange.
It's located on the driver side of the cylinder head and also contains the temp sensor.
Old 11-10-2010 | 01:25 PM
See the thing is...its empty...and its falling from somewher on the passenger side of the car...the water is dripping right down the side where the belts are..and further down almost where you would change the oil at...but the car never comes on...it straight drips right out...
Old 11-17-2010 | 11:52 AM
sparky450r's Avatar
I had a similar problem. Was dripping all over the belts (passenger side) and ran down into the skid plate. Nothing like pulling the skidplate off to change the oil and getting a coolant shower. My problem was the lower expansion tank hose. Seen here: http://www.ecstuning.com/Audi-TT_MKI...oses/ES251609/ . The plastic Y connecter tends to crack. Go out and feel around this piece under your hood or watch it after you pour in some D2O. Make sure you order some G12 while your at it for combined shipping.
azr3al
12-30-2011 12:37 PM
supacor24
06-03-2011 07:56 AM
inventorA6
04-15-2009 06:46 AM
less_of_me
05-02-2007 03:29 AM
Quick Reply: Coolant Leak
