Common boost leaks
Common boost leaks
So I got a boost leak somewhere and my mechanic is getting tired of my car sitting at his shop. Any common boost leaks happen. I am thinking about just going through and replaceing most of the hoses if there badly damaged.
RE: Common boost leaks
hes a pos mechanic if he cant find the leak
you need a compressor for that tool
ORIGINAL: Red_sapphire89
Most gas stations offer free air if you don't have a compressor, or access to one.
You may need a different fitting if you go the gas station route, but nonetheless it can be done.
ORIGINAL: ouTTie914
Yeah what's your point?
Here is the pressure tester I made. Its a PVC reducer with a end cap. I drilled / Tapped the end and then I got an air compressor gauge / on/off valve setup from lowes for like 4 bucks. This doesnt give me a TON of flexibility for testing at specific PSI, but its close enough.
outti-a4wd
01-16-2011 06:22 PM
