Combo valve is causing performance issues
Old 07-16-2007 | 12:18 PM
nero117amx's Avatar
Default Combo valve is causing performance issues
For a few months, my car has been lagging, and not performing as well. It seems that my gas mileage has been going down the tubes also. I attributed this to the DV valve, or MAF sensor.. Well, before I knew it, my check engine light went on. After that, my car ran great! (when the check engine light came on) I took it to my service shop, and the scanner read that there is incorrect flow in the exhaust system. They found the combo valve to be stuck in a closed/open (I don't remember which)position, and said I need a new one (for 170.00) They cleared the code, and now it runs like crap again. My question- if it's a valve, and it's stuck, how can my performance increase so much when the check engine comes ON.??
Also, if you guys have any suggestions where to buy one that would be great.
Old 07-16-2007 | 01:30 PM
rayveedub's Avatar
Default RE: Combo valve is causing performance issues
very wierd issue. can you post the code it threw.
Old 07-16-2007 | 01:32 PM
cincyTT's Avatar
I'm make believe
what valve?
Old 07-16-2007 | 01:57 PM
225tt's Avatar
Wastegate sticking open?? I dunno...
audiblacky
06-09-2010 12:46 AM
marcwest73
09-02-2009 01:43 AM
heloman28
11-24-2007 01:21 PM
elvisjer
04-02-2006 09:45 AM
reda4
01-16-2005 02:32 AM
Quick Reply: Combo valve is causing performance issues
