Collapsing quorstion!
Hi
I read about the collapsing TIH when you get a TT chipped. does this affect both engines?
i saw that alot of people have a samco hose to prevent it.
my question is, if i chip my car and get a less restrictive intake (like a VTDA), will that get rid of the collapsing problem as well?
(makes sense, more airflow = lower pressure difference between the air outside and inside the tube = no collapsing?)
thanks.
thanks.
RE: Collapsing quorstion!
the only thing that will stop the collapsing is a new tip. The stock 225 is all hose, and it collapses. An aftermarket silicon one is much stronger and will not collapse. www.Forgemotorsport.co.ukhas a vid on the site of it happening. Replace it and you will be good to go.
before anyone asks, the 180's have a 2 peice intake and will not have collapsing, if you do swap it out, you will see better and smoother flow. 225's need them to prevent/correct collapsing and increase airflow.
