Clutch VS. Power
#31
RE: Clutch VS. Power
ORIGINAL: Red_sapphire89
ellite is it loud how much faster does the car rev?A lot fasterHow do you like it?I love it, and there is no chatter, however mine was built to not chatter so I can't say how loud it would be with another setupDo you wish you got something different?Not at all, especially since I paid 1/3 the price for itwhat brand did you get?Fidanza how many lbs 9?I think it was 9lbs, but its less than that now since it had to be milled out some to work with my disc.
#33
Comments:
These units fit cars after 12/2000 production date (from chassis# 8N106001) and use the oem dual mass flywheel. These kits bolt to the stock dual mass flywheel. The SV21A and SV21S are for use with our high clamp VR6 units as a 9in upgrade from the oe 8.75 for all VW 1.8T cars. The SV21A weighs 7.5 lbs and SV21S weighs 12.5 lbs. A stock dual mass is also available for an extra $150 over the clutch cost.
Audi - TT Application[/b] Flywheels[/b] Aluminum Pressure Plate[/b] Year Span Engine Includes Steel Aluminum None Option None 2000 2001 1.8L 5sp FWD SA21S SA21A
Pricing: $299 $479 $ Choose Your Application Here
Performance Kits[/b] Stage 1 Stage 2 Stage 2+ Stage 3 Stage 3+ Stage 4 Stage 5 None Product Number: SA491 SA492 SA493H SA493 SA493F SA494 SA495 Torque Capacity: 300 355 395 420 510 420 600 Pricing: $479 $559 $639 $599 $749 $599 $749 Choose Here Comments:
This units fits cars through 12/00 production date (to chassis # 8N1006000) and fit the oem dual mass flywheel. With the SA21 flywheel upgrade, the clutch kits are upgraded to the 228mm size units, part number prefix SV36. See VW VR6 applications for information. Audi - TT Application[/b] Flywheels[/b] Aluminum Pressure Plate[/b] Year Span Engine Includes Steel Aluminum None Option None 2000 2004 1.8L 6sp,5sp quattro SA81S SA81A
Pricing: $419 $479 $ Choose Your Application Here
Performance Kits[/b] Stage 1 Stage 2 Stage 2+ Stage 3 Stage 3+ Stage 4 Stage 5 None Product Number: SA871 SA872 SA873H SA873 SA873F SA874 SA875 Torque Capacity: 350 411 456 517 578 517 684 Pricing: $529 $619 $689 $649 $799 $649 $739 Choose Here Comments:
Remove rotating mass with our lightweight clutch option for $79! includes slave cylinder Audi - TT Application[/b] Flywheels[/b] Aluminum Pressure Plate[/b] Year Span Engine Includes Steel Aluminum None Option None 2000 2003 1.8T
SA21S SA21A
Pricing: $299 $439 $ Choose Your Application Here
Performance Kits[/b] Stage 1 Stage 2 Stage 2+ Stage 3 Stage 3+ Stage 4 Stage 5 None Product Number: SV361 SV362 SV363H SV363 SV363F SV364 SV365 Torque Capacity: 305 365 395 414 525 414 560 Pricing: $359 $399 $449 $399 $549 $409 $549 Choose Here Comments:
These are 228mm VR6 pattern units built for use with SPEC billet single mass performance flywheels or OE G60 flywheels on 1.8T cars. Audi - TT Application[/b] Flywheels[/b] Aluminum Pressure Plate[/b] Year Span Engine Includes Steel Aluminum None Option None 2001 2003 1.8T 5sp FWD SV21S SA21A
Performance Kits[/b] Stage 1 Stage 2 Stage 2+ Stage 3 Stage 3+ Stage 4 Stage 5 None Product Number: SA351 SA352 SA353H SA353 SA353F SA354 SA355 Torque Capacity:
Pricing: $599 $699 $739 $699 $849 $699 $759 Choose Here Comments:
SA21S SA21A
#35
http://www.specclutch.com/
Comments:
steel- SA21S $299 12.5lbs
aluminum- SA21A $439 7.5lbs
so meanaudi a6 which do you have becaus ethats no where near 22lbs like you where saying....
Comments:
#36
to be honest with you, the Fidanza is unlikely to work with what you want... I have seen someone other than me using it but when we put it into the clutch testing device, it looked as if even the stock disc would have rubbed once it wore in some. so I just can't say that it will work fine for you
karthik67
08-01-2013 11:17 AM
ivanruiz817
09-16-2011 02:38 AM
Pablo_Ottawa
06-03-2011 01:10 AM
mas363
10-05-2010 11:48 PM
