Climate Control Codes
http://www.wak-tt.com/tt/climatecontcodes.htm
Try this...I saved it on my phone so I have it whenever im in the car
51 is the correct coolant temperature. As far as too hot I'm not sure. If there are no codes thrown and you haven't noticed any issues I wouldn't know where to start. Maybe a stuck thermostat. Partially open so it allows coolant through but not enough? I had a failsafe thermostat in my car and if it failed it would lock half open so the car wouldn't completely over heat but it hasn't failed so I don't know how I would tell.
I just re read your post and if it is staying at 90 which would be celcius that would be about 194 degrees fahrenheit. I think that would be right. The fluctuation between 102 and 104 I would say is unknown at least to me because that is for the malfunction counter for the vehicle speed....don't know what that is or what it does. I look at my speedometer
I have a 2003 a4 3.0 and I can't turn on the codes. I press recirculate button and up flow arrow together as indicated in my sites and I don't get the 1c to display in any of my dual temp displays. Help please. Btw, I can switch from f to c without problem pressing + and recirculate. !!
