Cincy...
Cincy...
I've received word from Arnold at pagand this is what he can do... Just wanted your opinion. He thinks this kit will make 340whp on pump gas.
Here is what I can do w/ a GT30 family based turbo...
manifold
GT3071R .64ar internal (this is more of a custom turbo that I do)
oil feed line kit
oil return line kit
GT restrictor
coolant line kit
3" SS DP
3" Inlet piping set
mounting stud kit
630cc injector set
intank fuel pump kit
software
charge hose w/ tbolt clamps (180hp version only)
4095 for the above. If you had something else in mind, like an externally
gated setup, let me know, but this is a very nice, solid performer
manifold
oil feed line kit
oil return line kit
GT restrictor
coolant line kit
3" SS DP
3" Inlet piping set
mounting stud kit
630cc injector set
software
RE: Cincy...
cincytt,
would the diode mod work with an 01 tt 225 hp?
since the diode fools the ecu in running more boost, couples with a n mbc, would that be benificial or disastrous?
but before i do this i'll up grade to an adj fpr.
thanks
and sorry if i hj the thread.
thanks
RE: Cincy...
ORIGINAL: smkn951
cincytt,
thanks
cincytt,
thanks
RE: Cincy...
I know this is a stupid question but I havent been on here long. How does Cincy Know all he knows? Is he a master tech on audi and vw or whats the deal? lol
Just wondering....
If hes the man to talk to I have a few questions myself :P
Just wondering....
RE: Cincy...
in reply to smkn951no one has done the diode mod on the 225 . Cincy has informed me that we would need a 4.4v diode which is pretty hard to find.the 4.4v diode would trick the car to seeing a max of 14.4psi not sending it into limp . hope that helps and if you do find a 4.4 diode and do the mod tell us how it goes.
RE: Cincy...
OK well here is a question.
Apr Chip gave me around 22 psi peak. 24 pounds if I disconnect the battery for about 5 min.
When I added the J valve I got a consistant 24-25 pounds. Some peaks at 26 then I would hit limp.
So can you trick it to do more if you had a chip and a diode?
Just wondering what the max I can get out of a K04 turbo on a 180 Quattro. Im just looking for that extra umph! I know a larger intercooler would help too but what about fuel injectors? What can be upgraded? for less than 1000 bucks?
RE: Cincy...
ORIGINAL: Jays TT
Just wondering....
Just wondering....
I assume he's done a fair share of reading and educating himself about cars. His knowledge goes far past the TT and into many other makes, which makes hime a good "all-around" source for information. Cars aren't "rocket surgery" and knowing how things work with engines, trannys, and the like, will apply to multiple situations....
If you'd quit slapp'n yer gob and educate yourself as opposed to question everything... maybe you'd learn something too.
RE: Cincy...
"I know this is a stupid question but I havent been on here long. How does Cincy Know all he knows? Is he a master tech on audi and vw or whats the deal?"
He did stay at a Holiday Inn Express last night...............
RE: Cincy...
ORIGINAL: andrei
is it just meor Cincy is a little shy...
He prob answered in PMs so i don't get to read the answers[&o]... fine, i see how it is.
