Can't Open Fuel Door Flap
Old 01-13-2010 | 03:24 PM
suziebee's Avatar
Default Can't Open Fuel Door Flap
I hadn't driven my 2001 Audi TT in over 2 months. The battery was completely dead. I replaced the battery and the car started right up. Everything is working just fine except the inside buttons to open the fuel flap and the inside trunk release. I can still open the trunk with the fob.
I thought it might be a fuse problem. I can't find in the Bentley Manual which fuse to check. Does anyone know which one it is? Also is there a way to manually open the fuel flap? I have one of those somewhat inacurate fuel gauges because of the bad instrument cluster and am not really sure how much fuel I have left. My trip odometer was reset to zero after the battery replacement; I've used that in the past to estimate fuel usage. I'd like to fill up before I run out of gas.
Help!
Old 01-16-2010 | 05:21 PM
redwheels's Avatar
There is a hide away door on the passenger side of the trunk wall. Inside of it there is a lever that opens the gas cap.
Old 01-16-2010 | 08:38 PM
rcf925's Avatar
Ditto, Also after battery problem it may take a few start cycles and it will start working again, I had mine do the same thing also 01 TT
Old 12-12-2013 | 02:27 PM
SassyJ's Avatar
I'm having the same issues with my 2002 Audit TT convertible. There are several problems with my car which include the not opening the trunk or gas tank cap. The keys no longer work for the alarm since the main trip computer display needs to be replace. I've been delaying in replacing this part since it will require the dealership to reprogram the system if replaced.
Would opening the hide away door on the passagner side of the truck wall work for my car as well?
Old 12-12-2013 | 09:03 PM
qiujianhua0216's Avatar
Mark for my car
Old 05-18-2014 | 05:23 PM
Terry Gentry's Avatar
I have an 2004 Audi A8 and the fuel flap door won’t open when I push the button. I think it might be a fuse, but where do I find it?
ericcota2003
12-02-2010 11:18 AM
J.C.
10-15-2010 04:44 AM
harimca
12-28-2009 05:50 PM
cukilo
03-28-2009 11:14 AM
romario
01-15-2008 02:23 AM
Quick Reply: Can't Open Fuel Door Flap
