In-Cabin boost controller install help
Old 04-27-2008 | 04:04 PM
themysteryman83's Avatar
Default RE: In-Cabin boost controller install help
fyi, on most boost controllers the more you tighten it down the higher the setting for boost. Loosen the screw and you get a lower boostsetting.
Old 04-28-2008 | 01:30 AM
Skipponator's Avatar
The dial has it labled which way to + and -, tighter down, the less boost. So since I hooked it up from the charge piping, it works like it is supposed to! BUT.... I plumbed the exhuast into the intake nipple and I do not really see more than 19psi, maybe 20, I run out of dial. So I can turn the dial down, and still see 19 until I get to a certain point.....
So my thought it this: I should unplug it from the intake, cap off the intake nipple so the air freely gets released from the exhuast hose, rather it being plumbed in-line with the incoming air which would cause resistance.... I will try this in the morning.
Thanks for the thoughts thus far!
-Skip
Old 04-28-2008 | 02:02 PM
cincyTT's Avatar
I'm make believe
It would be worth a shot. Venting it doesnt harm anything
Old 04-30-2008 | 02:31 PM
Well we called Turbo Smart today, and they said that on Euros, the in-cabins do not work and they are actually looking at discontinuing them. Apparently, the lines are too long and you cannot hit desired boost unless you have a Japanese car... So we yanked it out, and put an underhood in until my dual stage comes in next week.
Old 05-01-2008 | 02:45 PM
cincyTT's Avatar
I'm make believe
Yeah, they are like 2mm larger. You could always just run a thinner line to the boost controler.
01A4B5
06-17-2009 11:01 AM
BUCKET O BOLTS
07-28-2008 08:15 PM
Brandon2000s4
09-22-2006 06:29 AM
Dunzie182
08-13-2006 06:38 AM
audihere
08-12-2004 12:46 AM
Quick Reply: In-Cabin boost controller install help
