braided vacuum hose size?
Old 09-10-2007, 11:53 PM
themysteryman83's Avatar
Default braided vacuum hose size?
What's the size of the braided vacuum hose under/around the intake?
Thanks!
Old 09-11-2007, 12:02 AM
neur0tic's Avatar
Default RE: braided vacuum hose size?
3.5mm
Old 09-11-2007, 12:17 AM
cincyTT's Avatar
I'm make believe
Get tons of that and 6mm so you can change just about anything you need to
Old 09-11-2007, 12:40 AM
neur0tic's Avatar
I just ordered 25' of 3.5mm, 15' of 6mm, and 15' of 8mm.
All in high temp platinum silicone (color = silver)
Old 09-11-2007, 12:56 AM
moeron7's Avatar
ORIGINAL: neur0tic
Where did you order yours from. What was the grand total for that? Also did you need that much or did you just wanna make sure you had enough?
Old 09-11-2007, 01:04 AM
cincyTT's Avatar
I'm make believe
That should be more than enough
Old 09-11-2007, 01:30 AM
moeron7's Avatar
ORIGINAL: cincyTT
would 10 feet of each be enough?
Old 09-11-2007, 01:41 AM
cincyTT's Avatar
I'm make believe
you need to cover all of this
1 - Vent line
From gravity valve at fuel tank See "Fuel Tank, Removing and Installing" item no 8. See: Fuel Tank\Service and Repair
2 - EVAP canister
With Evaporative Emission (EVAP) canister purge regulator valve -N80-
3 - Turbocharger
4 - Check-valve
For EVAP canister system
5 - Pressure unit
For Boost Pressure Regulation Valve
6 - Deceleration shut-off valve
7 - Wastegate bypass regulator valve - N75
Valve is activated (pulsed) by the Engine Control Module (ECM)
Checking activation: See Output Diagnostic Test Mode (DTM), activating. Refer to "On Board Diagnostic". See: Computers and Control Systems\Testing and Inspection
8 - Brake booster
9 - Check-valve
For brake booster
10 - Air filter with Mass Air Flow (MAF) sensor - G70 -
11 - Pressure control valve for crankshaft housing ventilation
12 - Combination valve
For Secondary Air Injection (AIR) system
Checking. See: Emission Control Systems\Air Injection\Testing and Inspection
13 - Fuel pressure regulator
14 - Check-valve
15 - Recirculating valve for turbocharger -N249-
16 - Secondary Air Injection (AIR) solenoid valve -N112-
17 - Crankcase ventilation
18 - Check-valve
19 - Charge air pressure sensor -G31- / charge air cooler
20 - Secondary Air Injection (AIR) pump motor - V101 - *
Checking function. See: Emission Control Systems\Air Injection Pump\Testing and Inspection
21 - Vacuum reservoir
So i would go with more than 10'
Old 09-11-2007, 01:51 AM
neur0tic's Avatar
hightempsilicone.com
I opted for that much to ensure I had plenty to spare.
$85 shipped
Old 09-11-2007, 02:14 AM
Cool thanks guys, where did you get your silicone hoses?
Quick Reply: braided vacuum hose size?
