Boostmachine in
Boostmachine in
love it. no more crazy boost spikes, hits 20psi in 3rd settles and holds 18psi until 5400-5600 rpms then slowly settles down. the boost onset control is nice too, the boost lost between shifts is gone.
RE: Boostmachine in
ORIGINAL: cincyTT
Knowing your taste, im guessing awe vent gauge.
Nvm... anyhow, Can the boost machine be installed without the ****? I only ask because I'd like to go full up stage 3 modshack... but I wonder whether I need to do them in order. I have the VTDA installed already.
RE: Boostmachine in
You can get the AWE gauge @ a bargain ($80 less) if you order the kit for the A3 instead of the TT. Same gauge, comes with trim ring and install kit. Thats what I did, requires a little modification like the Modshack install, if you are interested I can give you pics/info.
