boost 180hp
boost 180hp
After boost gauge install, 9psi is max i'm seeing. also i have 18 hg vac @ idle and 20 hg when moving in gear w/o gas
I have a hosetech silicone set i'm going to install soon... do you think that will fix the problem?
RE: boost 180hp
It could be a dv or just load. Until you show the dv is bad or a boost leak, im going with load. Go down the street at ~45mph in 5th and give it gas, you should see 11psi and sometimes 12-13
RE: boost 180hp
What boost guage did you get?
and what company did you buy your silicone hoses from?
I went to hightempsilicone.com and I still havent got SH*T! except for acredit card charge.
I totaly forgot about that thread with neurotic and mysteryman83 on how they got charged and never got anything.
