Boost in "N" -vs- in Gear
Old 02-21-2008 | 09:52 AM
freegeek's Avatar
Default RE: Boost in "N" -vs- in Gear
This is a typical 1st, 2nd, 3rd gear plot of requested boost (white line) and actual boost (red area), you can see here the requested boost and actual boost drops off for gear changes.
It would be interesting to see what the plot would look like if you didn't lift of the accelerator pedal.
I haven't seen the boost register while revving in neutral but then again I haven't really revved it hard for any more than a blip, don't want to disturb the neighbors.
Old 02-21-2008 | 11:41 AM
taifighter's Avatar
is that a screen shot from the VAG COM program?
Old 02-21-2008 | 03:14 PM
cincyTT's Avatar
I'm make believe
^ that is his sw that is like vagcom
ORIGINAL: freegeek
Boost in 1-2 gears will be less than in 3-5/6 gears since again load. As for not lifting, the boost would still drop since the engine is still disengaged and the turbo will slow slightly (less exhaust gas) even though the dv/bov doesnt open (yes, if you shift without letting up the bov doesnt open).
Old 02-21-2008 | 06:08 PM
freegeek's Avatar
ORIGINAL: taifighter
No, its from the one and only liquidTT multi gauge, a little project I've been working on.
Old 02-21-2008 | 10:07 PM
Skipponator's Avatar
That is a nifty guage, what can it do?
Old 02-21-2008 | 11:15 PM
XCLR8TT's Avatar
VagCom is not only handy for reading and clearing MIL codes, but it allows you to log just about everything going on with your engine. All of the sensor readings that get processed by the ECU can be logged, saved, and analyzed to help diagnose a wide range of problems from loss of power, misfires, sensor failures. Check out their FAQ at ROSS-TECH FAQ
Old 02-22-2008 | 04:12 AM
freegeek's Avatar
ORIGINAL: Skipponator
Here is a video of its features, its about 3Mbytes. http://racediagnostics.com/images/Movie.wmv
Feature list
Main Menu
Gauge Display
Graph Display
G force
Speed timing
Faults and adaptations
Setup
Sub Menus
Gauge Display
Engine power
Torque
Boost pressure
Cmd pressure
Mass Air Flow
Air Fuel Ratio
Air intake temp
Exhaust temp
Coolant temp
N75 position
Graph data
BHP
Torque
Boost pressure
Cmd pressure
Mass Air Flow
Air Fuel Ratio
Air intake temp
Exhaust temp
Coolant temp
N75 position
Missfire
[/align]G - Force Display[/align][/align]Bar Graph or scatter plot[/align][/align]Left
Right
Acceleration
Deceleration
[/align]
Speed timing
0-60mph acceleration timing
[/align]0-100mph acceleration timing
[/align]
Faults and Adaptations
Display Fault Codes
[/align]Clear Fault codes[/align]TBR
[/align]
[/align]Setup[/align]Big turbo setting or standard turbo[/align]
  #18
Old 02-23-2008 | 02:52 AM
That is a nice setup, similar to my Interceptor in my Prix, but this seems to be much better! Sounds like there is only one out there? Why?
  #19
Old 02-23-2008 | 06:26 PM
freegeek's Avatar
I hope to have a few ready for sale by mid March at the web site below.
vdubb2bmw
03-02-2010 01:27 PM
vdubb2bmw
03-01-2010 01:36 PM
vdubb2bmw
02-28-2010 08:25 PM
beachchair
02-17-2008 12:47 PM
kaklexicon
05-01-2006 06:05 PM
