Big turbo FRIDAY (pictures added)
Ok so I will have almost everything for my big turbo this friday and im pumped! What I still need.....
Injectors....440?
Manifold...??
tuning fuel software...where should i go for this. Also i will need to have every tuned where can i go for this?
[IMG]local://upfiles/16834/49EBE0C427E94561AF3A206BB3C10208.jpg[/IMG]
[IMG]local://upfiles/16834/DA5D78E4CB7B4DA2BB02E0E3DC259B8D.jpg[/IMG]
[IMG]local://upfiles/16834/B411E984091D40519CA1A20317BF7F5E.jpg[/IMG]
Injectors....440?
Manifold...??
RE: Big turbo FRIDAY (pictures added)
I think im going to piggyback the stock ECU so all the ABS and cabin electronics still work but, im going to run a megasquirt to run the engine. Does anyone know what specific model i need. Also does anyone know if there are BUS MAPS created for something like this.
That dividedhousing is going to be such a waste if you dont get a divided manifold. Is that a .63 housing, it looks bigger?
I dont know much about megasquirt but i know someone that is running it on his '00 gti that is going to bea drag car. His vortex sn is whiteG60 and his name is Ian. He is a good guy and should be able to help you out.
New turbo got the .63 and this one i think is close to 70. If i keep the boost at a moderate level it will be streetable not legally streetable but i will be able to drive it on the streets. I was talking to my mech and he said without a new dif ill be spinning the tires in 4th.
So you have another turbo or housing, im lost. I think last i heard, most 60trims will have 320ish whp at 18psi. Which the max for 440's. If you want that revo hookup, you can get the 580 file and should be good to 400hp
