Big Turbo First Start!
Old 05-17-2008 | 03:59 PM
Audi858's Avatar
Default RE: Big Turbo First Start!
Could I use lemmi to adjust the stock ecu's A/F so it doesnt run lean. Would it be drivable?
Old 05-17-2008 | 05:00 PM
cincyTT's Avatar
I'm make believe
The problem with using the stock programming is that the timing and fuel curve are nothing like they will be with a larger turbo and injectors. If you drop the boost down and run off the wastegate, you should be alright, but you would need to use the stock maf and injectors. Just dont run more power than the injectors can handle
Gus2.8supercharged
04-22-2015 10:39 AM
rory2523
11-14-2010 09:58 PM
GBD
09-15-2010 04:02 AM
raptor7400
02-01-2010 01:52 AM
Stinky
03-08-2004 03:30 PM
