Big problem need advice
I have an issue with the shop that I take my car to. I have two parts to the question but I need the first part answered before I can ask the next.
I dropped my car (for a install) off at my shop earlier this week (Monday) because my OSIR carbon fiber rear valence just came in.
I got a phone call yesterday from the shop telling me that the car's immobilizer turned on. This was due to the fact that I gave them a valet key that was just sent to me in the mail (from the seller I purchased the car from about a month ago).
I am wondering what exactly does it mean if the immobilizer is on and how is it activated?
immobilizer does just that.
Electronic immobilizer
The immobilizer is an electronic anti-theft device. It is activated when the ignition key is removed and, together with the engine control unit, largely prevents unauthorized starting of the engine. The system uses a transmitter and receiver unit in the ignition key (transponder). Whenever an attempt is made to start the engine, it transmits a new code to the car’s electronics. The immobilizing is only cancelled if the key sends an authorization code. New encryption technology protects the system against electronically copied vehicle keys.
Note:
No system can provide 100% protection against theft. If thieves possess the necessary skill and determination, they may even be able to overcome the electronic immobilizer.
Note:
They told me my immobilizer turned on because the valet key I gave them was not programmed with my car so it started my car and after that my car's immobilizer turned on.
So what I am getting from this is that I gave them a wrong key and when they tried to use it, my immobilizer activated...
so the valet key i got that was not programmed immobilized my car but my other 2 key fobs still work.. whats going on? what does the immobilizer do if my two key fobs still work!?
I dealt with this same mearlier in the week. I only have a key with no remote because I lost my other one. I called the Audi headquarters and they stepped me through the following process.
Step one: Place the key in the ignition and remove the car from safe mode (IF neccesary
Step 2: Get out of the car and locked it from the outside.
Step 3: Then reinsert the key into the driver's side key hole and turn it fully into the unlocked direction TWICE, which should be towards the front of the car twice.
Step 4: Relock the car with the key from the outside.
Step 5: UNlock door with the key from the outside.
Step 6: Start car
Step 6: Start car
Don't tell me you took the car into a shop to install a valance did you? Its 4 bolts (or screws) to loosen and then just snaps off. Install takes ~15min.
Something similiar happened to me once but in my case nothing would work in the car. I couldn't even open the gas tank with the button. I did similiar steps (probably the exact same) as listed above and everything was fine again. It is some type of reset.
