Best cat.
Old 06-26-2007 | 11:05 AM
neur0tic's Avatar
Default RE: Best cat.
ORIGINAL: Wintermute
So would a 42 draft high flow cat pass inspection & not throw on my CEL? Cause I plan on buying their test pipe & just switching it out every inspection. & why should I be working about the CEL coming on when all I'm changing is the exhaust?
You have an O2 sensor back there.
Old 06-26-2007 | 05:54 PM
gTT's Avatar
gTT
so does that mean I can't remove the cat and put a downpipe? that's suck...
i am in N.Cal.
Old 06-26-2007 | 06:03 PM
cincyTT's Avatar
I'm make believe
you can buy a new dp with a cat, its not going to make a huge difference between cat and no cat.
Old 06-26-2007 | 06:26 PM
cincyTT's Avatar
I'm make believe
speaking of, read this
Old 06-27-2007 | 06:32 AM
gTT's Avatar
gTT
thanks, cincyTT
Old 06-28-2007 | 04:25 AM
Anos's Avatar
Alot of tests that I have seen Vs for example Magnaflow (Carounds) Highflow Catalytic Converter Vs a Straight pipe showed Carsounds High Flow did ~350CFM on a Beasty V8 and with a straight pipe/no catalytic it was something like 407CFM. Boosted ~2-3HP. May as well just go with a high flow if you do make a decision. Less hassles with Emissions and legal =P
Old 06-28-2007 | 10:09 AM
neur0tic's Avatar
if you put a cutout after the downpipe... will it even make an impovement since the DP is still 2¼" I mean... the small diameter IS the reason right? The cutout wont change the restriction of the small DP
