bad n75 valve?
Old 11-17-2011 | 06:26 PM
IronCobra53's Avatar
Default bad n75 valve?
my car has been boosting weird lately, it will boost about 9-10 psi then on the next pull boost 12psi, then yesterday it spiked to 15 then i let off, it still pulls fine n idles normal, but if im cruising at 2800 rpm on the interstate n step on it without downshifting (jst to pass a truck or someone etc...) it would spool right up to 10-12 psi now sometimes it wont go past 5 or itll spool rly slow, recently i put a bigger spectre filter (autozone filter) and i had to move it about 3 inches farther away from my maf to clear my breather filter, i doubt tht has anything to do with it (i hve a p-flo intake btw) but thought id mention it jst incase, any ideas?
Old 11-17-2011 | 07:45 PM
cincyTT's Avatar
I'm make believe
Just sounds like changes in load. If you are really concerned, run a host leak test and search for exhaust leaks
Old 11-18-2011 | 12:21 AM
like exhaust leak at the downpipe, or the manifold?
Old 11-18-2011 | 04:37 PM
cincyTT's Avatar
I'm make believe
Any connection between the head and downpipe
Old 11-28-2011 | 10:11 PM
thnx cincy ill check it out
elduderino200
07-08-2015 04:35 PM
Jfk63
03-23-2011 12:14 PM
gabeguimaraes
05-22-2009 05:46 PM
07titanium
B7 Models
03-05-2009 09:29 PM
